Что нового в версии:
http://blog.mediacoderhq.com/changelog/
0.8.61 (Apr 5 2020)
Fixed a possible MediaCoder Pass validation issue
x265 3.3+12
tsMuxeR 2.6.15
0.8.61
• Fixed a possible MediaCoder Pass validation issue
• x265 3.3+12
• tsMuxeR 2.6.15
0.8.60
• FFmpeg 4.2.2
• x265 3.2+34
0.8.59
• Hardware accelerated video decoding via FFmpeg
• AMD AMF accelerated video encoding via FFmpeg
• FFmpeg 4.2.1
• x265 3.2+9
• MediaInfo 19.04
0.8.58.5985
• x265 3.1+11
• FFmpeg 4.2
0.8.58.5982
• Fixed VP8/VP9 encoding
• Added hint option on Container tab
• Minor bugfix
• Built with Visual Studio 2019
• x264 r2969
• x265 3.0+44
• FFmpeg 4.1.3
0.8.57.5960
• x265 3.0+3
• Added HDR BT2020 compliant option for x265
0.8.56.5950
• x264 r5935
• x265 2.8+74
• Some UI fresh-up
0.8.55.5938
• Updated x264, x265, FFmpeg
• Added overlay filter options for FFmpeg
• Some minor fix-up
• Possibly the last revision for 32-bit version
0.8.53.5930
• Fixed A/V sync issue when FFmpeg as muxer
• Fixed DTS encoding issue
• FFmpeg 3.4.2
• x265 2.4+14
0.8.52.5920
• Improved 10-bit video encoding with x264, x265 and NVENC
• Allowing x265 to encode in I444 colorspaces
• Added x265 main-intra profile option
0.8.51.5911
• Fixed incomplete display of media file properties
• Changed default multiplexer to FFmpeg for H.265 encoding
0.8.51.5910
• NVENC 8.0
• MKVToolnix 18.0.0
• MP4Box 0.7.0
• MediaInfo 17.10
0.8.50.5900
• Built with Visual Studio 2017
• Fixed a multiple audio track bug
• FFmpeg 3.4
• x264 r2851
0.8.49.5890
• Fixed output file name formatting issue
• Fixed image to video conversion with external audio
0.8.48.5888
• Fixed parsing issue for Blu-ray ripped files
• FFmpeg 3.2.4
0.8.48.5885
• Added Suptitle AviSynth plugin (Bluray subtitle renderer)
0.8.48.5882
• Fixed an occasional audio decoding blocking issue
• Minor GUI adjustments for Windows 10
• x265 2.3+9
0.8.47.5872
• Fixed FFmpeg source scaling issue
• Fixed FFmpeg source delogo not working issue
0.8.47.5870
• Added native 10-bit YUV support
• Workaround for FFmpeg of muxing HEVC in TS
0.8.46.5866
• x264 r2721
• MPlayer/MEncoder r37900
0.8.46.5865
• Updated with NVENC 7.0
• Updated with Intel Media SDK 2016
0.8.45.5852
• Fixed compatibility issue with FFmpeg 3.0
• Using FFmpeg as default video source instead of MEncoder
• Fixed image file causing crash bug
• x264 r2705
• x265 2.0+2
• MediaInfo 0.7.87
• FFmpeg 3.0.1
0.8.43.5830
• Fixed some AviSynth issues
• Fixed multiple file concatenation by AviSynth and FFmpeg as video source
• Improved support for MXF format
• x264 r2692
• x265 1.9+140
0.8.42.5822
• Fixed FFmpeg video source breakage
• x265 1.9+104
0.8.42.5820
• Fixed HEVC/H.265 in MPEG-TS muxing issue
• tsMuxer 2.6.12
• x265 1.9+32
• FFmpeg 3.0
• MPlayer/MEncoder r37839
0.8.41.5818
• x265 1.9+15
• QAAC 2.58 (new x64 build with QT DLL files)
• MP4Box reversed to 0.5.2 r998 for stability
0.8.41.5816
• Fixed HTML based UI not loading on Windows XP issue
• Fixed auto level filter issue
• FFmpeg 2.8.5
• x265 1.8+209
• x264 r2665
• MKVToolnix 8.8.0
0.8.41.5810
• NVENC 6.0
• FFmpeg 2.8.4
• x265 1.8+188
0.8.40.5802
• Fixed a GUI issue in previous build
0.8.40.5800
• Fixed WMV file parsing issue
• Updated French translation
• MP4Box 0.5.2 rev1110
• MPlayer/MEncoder svn-r37565 (x64)
• MKVToolnix 8.6.1 (x64)
• x265 1.8+167
• MediaInfo 0.7.80
0.8.39.5790
• New feature of stopping after completion of current job
• FFmpeg 2.8.2
• x265 1.8+106
• MediaInfo 0.7.79
0.8.38.5783
• Fixed Windows XP compatibility issue of build 5780
• Reverted MKVToolnix to 8.0.0 for Windows XP compatibility
• x265 1.8+31
• x264 r2638
0.8.38.5780
• Fixed 2-pass encoding issue with multiple audio tracks
• Updated x265 1.7+482
• MPlayer/MEncoder svn-r37527 (x64)
• FFmpeg git 20150928
• MKVToolnix 8.4.0
• MediaInfo 0.7.77
0.8.37.5770
• Rebuilt with Visual Studio 2015
• Fixed NVENC bitrate control issue for ABR and CQP mode
• Updated Brazilian Portuguese translation
• Updated Intel Media SDK Encoder
• MPlayer/MEncoder r37465 (x64 build)
• MediaInfo 0.7.76
• x264 r2597
* x265 1.7+374
