Intel Core™ i-series (4th Generation or above) or equivalent AMD CPU model.
Full-HD video editing: Intel Corei5 or AMD Phenom II X4 above recommended
2K/4K/360° video editing***: Intel Corei7 or AMD FX series above recommended
Graphics Processor (GPU)
128 MB VGA VRAM or higher (1 GB or higher VRAM and OpenCL capable are recommended)
DirectX 11 compatible for 360° video editing.
[NVIDIA]
GeForce GT/GTS/GTX 200/400/500/600/700/800/900/1000/2000/3000/4000 Series
GeForce RTX 2000 series
[AMD / ATI]
AMD APU Family with AMD Radeon™ HD Graphics: A-Series, E2-Series, C-Series, E-Series, G-Series
AMD Radeon™ Graphics: RX Series, R9 Series, R7 Series, R5 Series,HD 7000 Series, HD 6000 Series
ATI Radeon™ HD Graphics: 5900 Series, 5800 Series, 5700 Series, 5600 Series, 5500 Series, 5400 Series
ATI FirePro™ Graphics
ATI Mobility Radeon™ HD: 5800 Series, 5700 Series, 5600 Series, 5400 Series
ATI Mobility FirePro™: M7820, M5800
[Intel]
HD Graphics (4th Generation or above)
Memory
4GB required (8GB or above recommended)
Sound Card
Windows compatible sound card is required.
Screen Resolution
1024 x 768, 16-bit color or above.
Other
Windows Media Player (Media Feature pack) is required.
Microsoft WebView 2 runtime is required.
The AI related features require Windows11/10 system components "AVX2" and AI computing module to operate the features.
Internet connection is required to download and install these AI components from the CyberLink server.
Occasional updates may also be downloaded in the future for these features. Minimum system requirement of AVX2 instruction set: Intel
Haswell (4th generation) processor: Core i7-4770 (only Core and Xeon branded), and above AMD
AMD A8-7670K and above
AMD Ryzen™ 3 1200 and above
PowerDirector - самое быстрое и передовое программное обеспечения для редактирования видео. В состав PowerDirector входит комплект самых передовых и простых в использовании средств для создания профессиональных видеоматериалов. Также в наличии имеется технология обработки видео (SVRT), NVIDIA CUDA, ATI-Stream для многоядерных блоков обработки, которые помогут вам завершать проекты фильмов и сохранять их в высоком качестве быстрее, чем это способны делать другие программы, доступные на рынке! Программа включает в себя также удивительный набор магических средств для удобного редактирования фильмов более быстро и лучше. С помощью этого набора инструментов владельцы цифровых камер смогут превратить материалы любительской съемки в полноценный видеофильм профессионального качества. Новая версия может похвастаться расширенной поддержкой форматов высокой четкости, а также позволяет создавать видеопродукцию, распространяемую на дисках Blu-ray Disc (в форматах BDAV и BDMV). Вниманию пользователей предлагается поддержка функции PiP (картинка в картинке), впечатляющая коллекция эффектов переходов, инструменты для подготовки высококачественных «слайд-шоу» и создания интерактивных меню и многое другое.
Доп. информация
Создайте высокое качество видео быстро с помощью усовершенствованного средства создания Magic Movie.
Используйте Content Aware Editing (Редактирование с учетом содержимого), чтобы быстро найти самые увлекательные части и подкорректировать плохие части видеоклипов.
Ускорьте работу своего компьютера с помощью технологии TrueVelocity™ 3.
Отправьтесь в полноценное путешествие по редактированию с помощью AudioDirector, ColorDirector и PhotoDirector.
Импортируйте видео 2K и 4K Ultra HD, а также видео или аудио до каналов 7.1 для редактирования.
Усовершенствованная дизайн-студия PowerDirector (конструктор картинки в картинке, конструктор частиц, конструктор титров, конструктор меню) для более точного, мощного и творческого редактирования при создании фильмов и дисков.
Создайте 4 градиентных цвета окантовок и текста в конструкторе картинки в картинке, конструкторе титров и конструкторе меню.
Импортируйте и редактируйте видео с помощью звукового канала 5.1 без понижающего микширования до канала 2 во время предварительного просмотра.
Используйте обновленные инструменты Исправить/Улучшить для корректирования освещения и баланса белого в мультимедиа или дрожания вращающейся камеры в видео.
Просмотрите все кадры на временной шкале видеофайлов с чистотой кадров 50 или 60 кадров в секунду.
Выпускайте фильмы в формате видеофайла в Matroska (MKV).
Выводите видео в одном из многочисленных форматов 2K или 4K Ultra HD.
Отключите окно предварительного просмотра для увеличенного просмотра видео и временной шкалы.
Редактируйте и настраивайте сочетания клавиш PowerDirector для более персонифицированного редактирования.
Потрясающе высокая скорость редактирования видео;
Мощные инструменты редактирования;
Максимум творчества;
Возможность загрузки видеоматериалов напрямую в социальные сети в полном качестве HD;
Загрузка видео на IPAD, iPhone, IPod, BlackBerry, PSP, Zune и многие других мобильные устройства. Функции CyberLink PowerDirector:
Импортировать мультимедиа
3D-видео (MVC, горизонтальная стереопара)
3D-фотографии (MPO, JPS)
MPEG-1, MPEG-2
FLV, MKV, DSLR
Файл AVCHD с аудиофайлом DDCD (.M2T/.M2TS)
Файл AVCHD с аудиофайлом LPCM (.M2T/.M2TS)
Устройство Apple/PSP MPEG-4
Видео 4K (более 1920*1080)
Клип с поддержкой Dolby Digital 2
Клип с поддержкой Dolby Digital 5.1
Клип с поддержкой DTS 5.1
Клип с поддержкой WAV 7.1
MOD, TOD
Клип WTV (видео MPEG2)
Клип WTV (H.264)
DVR-MS
Функции захвата
Захват с видеокамеры HDV
Захват с тюнера DVB-T
Захват аналогового ТВ-тюнера
Захват с внешнего или оптического устройства
Захват с видеокамеры AVCHD
QuickScan
SmartCaption
Копирование DV
Функции правки
Преобразование видео и фотографий 2D в 3D
3D-эффекты картинки в картинке
3D-эффекты титров
3D-эффекты частиц
3D-эффект перехода
3D-видеоэффект
Регулировка ориентации 3D
Улучшения видео TrueTheater
ColorDirector
Обратное воспроизведение видео
Скорость видео — технология вставки кадров
Magic Cut - установка критериев
Стабилизатор видео - исправить эффект дрожащей камеры
Конструктор Magic Motion
2D-шаблоны Magic Style
Magic Music SmartSound
Шаблоны демонстрации слайдов
Панель настройки ключевого кадра
Предварительный просмотр качества в режиме Full HD
WaveEditor
AudioDirector
Создание файла тени
Важно:
CyberLink удалил автономную активацию кодеков, дополнительные функции вывода h.265, поэтому вам необходимо разрешить соединения с интернетом. Активация кодека будет выполняться автоматически при пропатченной установке.
Если вы используете автономный режим или заблокировали в брандмауэре или в файле хостс(hosts) доступ программе в инет, разблокируйте их. Удалите в файле hosts записи, если есть
Удалите предыдущие версии. Очистите остатки реестра и пользовательские файлы(подробности в файле Instructions.txt) 1. Установить CyberLink PowerDirector Ultimate. После окончания установки не запускать! 2. Запустить Reg Patch.reg и согласиться с внесением изменений. 3. Файл Simkey(из папки Fix) поместить с заменой в папку с установленной программой 4. Для активации кодеков импортируйте MKV или MP4, нажмите кнопку «Export», выберите HEVC или любой другой кодек, который вы хотите, и все готово. При запуске отказаться от участия в программе по улучшению PowerDirector -- Антивирусные программы могут по ошибке идентифицировать патчи, кейгены, пролеченный(е) файл(ы) как вирус Либо добавляйте папку с программой в исключение своего антивируса при скачивании и отключайте его на время установки, либо ищите другой источник взлома.
Не нужно в комментариях писать про возможно обнаруженный "вирус", пишите свои подозрения сразу модератору(это тут),
но прежде чем писать, прочитайте написанное ниже по ссылке.О "ВИРУСАХ" В РАЗДАЧАХ ЧИТАТЬТУТ
