--Aiarty Video Enhancer 3.6 [Multi]--
Версия программы3.6
Официальный сайт: Aiarty
Язык интерфейса: Английский, Немецкий и другие Лечение: в комплекте
Windows: 10(x64) (version 1809 for CPU and above, 1903 for GPU and above)
CPU: Any x86-64 (AMD64/Intel64)
RAM: 8GB (Recommended: 16 GB or above)
GPU:[list=]
DirectML hardware acceleration:
- AMD - Radeon HD 7000 series or higher
- Intel - Haswell (4th-gen core) HD Integrated Graphics or higher
- NVIDIA - GeForce GTX 600 series or higher
Note: DirectML hardware acceleration requires graphics cards that support DirectX Feature Level 12.0 and above. This is a hardware capability and cannot be updated via driver upgrades. For dedicated graphics cards, at least 4GB of VRAM is required (8GB or more recommended), and make sure to update your graphics drivers to the newest version. To check your DirectX Feature Level, open Task Manager, click on the Performance tab, select GPU, and there you'll find the FL value.
- TensorRT hardware acceleration: For optimal performance with TensorRT hardware acceleration, please refer to the requirements below, depending on your NVIDIA GPU series:[list=]
- For NVIDIA 20, 30, 40, and 50 Series GPUs:
- NVIDIA GPU Compute Capability: 7.5 or higher
- Compatible models: GeForce GTX 2050 or higher, specifically supporting the latest NVIDIA GeForce RTX 50 Series graphics cards (NVIDIA Blackwell Architecture).
- CUDA Driver Version: ≥ 12.8
- For NVIDIA 10 Series GPUs (New Support):
- NVIDIA GPU Compute Capability: 6.1 or higher (NVIDIA Pascal architecture, e.g., NVIDIA 10 series).
- CUDA Driver Version: ≥ 11.8
Note:
- VRAM: For faster inference using TensorRT on Windows, ensure your hardware has at least 4GB of VRAM (minimum GTX 2050). 8GB of VRAM or more is recommended.
- Driver Updates: If your NVIDIA graphics driver version is not sufficient for full TensorRT functionality, the software will prompt you to update and may default to DirectML acceleration. Updating your drivers to the latest version is strongly recommended for optimal performance.
- DirectML and OpenGL: DirectML's minimum requirement remains DirectX 12 (DirectX Feature Level 12.0 and above). OpenGL 3.3 support remains unchanged.
Aiarty Video Enhancer — программное обеспечение для улучшения качества видео с помощью ИИ от Digiarty, позволяющее добавлять больше деталей, устранять шумы, устранять размытие, повышать разрешение и восстанавливать видео с дефектами до четкости 4K. Благодаря специализированным моделям искусственного интеллекта оно обеспечивает превосходное качество изображения с турбо-скоростью, расширяя возможности создателей контента и любителей видео.
Восстановление чистого звука.Модуль подавления шума анализирует и улучшает звуковые дорожки. Всего в один клик удаляется фоновый шум и повышается разборчивость речи.
- Улучшение до 4K с сохранением деталей. Специальные ИИ-модели преобразуют видео низкого качества, с заиканиями или шумами в четкое и плавное 4K-видео. Наслаждайтесь кинематографическим качеством и погружающим визуальным рядом.
- Идеально плавное замедление. Модуль интерполяции кадров использует ИИ для создания новых высококачественных кадров, обеспечивая плавное замедление до 8X или 16X.
- В 3 раза быстрее. Экономия времени. Благодаря передовой технологии ИИ, режим Turbo от Aiarty обеспечивает масштабирование до 4K в реальном времени с превосходным качеством — в 3 раза быстрее по сравнению с другими ИИ-инструментами.
- Оптимизация для Nvidia / AMD / Intel. ИИ-модели в Aiarty полностью используют возможности поддерживаемого оборудования, обеспечивая до 95% загрузки GPU для быстрого масштабирования и генерации деталей.
- Лидирующее решение в отрасли по улучшению и масштабированию видео с помощью ИИ. Благодаря собственной базе обучающих данных для видео и изображений, адаптированные ИИ-модели в Aiarty Video Enhancer обеспечивают лучшее качество при оптимальной скорости обработки на GPU. Они специально разработаны для повышения резкости, восстановления поврежденных и деградировавших видео, а также улучшения кадров с низким освещением.
- Плавное движение. ИИ-модуль интерполяции кадров в Aiarty увеличивает частоту кадров до 90fps, 120fps и выше, создавая новые кадры для плавного замедленного воспроизведения.
Благодаря ИИ-моделям, обученным оценке движения и компенсации, создаваемые кадры получаются естественными и последовательными, без «желе»-эффекта, размытия или искажений.
Идеально подходит для динамичных сцен, таймлапсов, анимации, 3D-графики, AI-фильмов и другого видеоконтента, где важна плавность и согласованность движения.
- Кристально чистый звук. Aiarty использует продвинутые ИИ-алгоритмы для удаления фонового шума и улучшения речи. Идеально подходит для восстановления звука в влогах, подкастах, лекциях, концертных записях, семейных видео и других материалах.
Поддерживаемые форматы ввода:
.avi, .flv, .mp4, .mkv, .mov, .webm, .wmv, .ts, .m2ts, .mts, .m4v, .3gp, .3g2, .rm, .rmvb, .mpeg, .mxf, .ogv, .vob, .asf, divx, and .f4v
Поддерживаемые форматы вывода:
.mp4, .mov
Поддерживаемые кодеки:
H.264, H.265, ProRes, AV1
Chroma formats in settings: YUV 4:2:0, 4:2:2, or 4:4:4 (availability depends on codec and profile)
- Добавлен новый ползунок «Сила», позволяющий регулировать интенсивность эффекта HDR, благодаря чему качество видео и динамический диапазон будут соответствовать вашим конкретным требованиям.
- Режим Step Mode (вычисление с мозаичным расположением видеокадров) позволяет обеспечить более высокое качество изображения при значительно меньшем потреблении vRAM, что сопровождается небольшим снижением скорости вычислений ИИ.
- Функция «Super-Resolution Strength Control» позволяет регулировать степень усиления и резкости, обеспечивая идеальный баланс между четкостью и естественностью изображения.
- Добавлен флажок «Суперразрешение видео». По умолчанию он включен для улучшения качества изображения и увеличения разрешения. Снимите этот флажок, чтобы пропустить процесс улучшения качества и выполнить только цветовую коррекцию, интерполяцию кадров или удаление шумов из аудио, если это необходимо.
- Интеллектуальное преобразование 8-битного SDR-контента в 10-битное HDR-видео для получения более плавных переходов и насыщенных, реалистичных цветов. Лучше всего использовать в сочетании с функцией «Цвет».
- Добавлена возможность восстановления исходного цветового профиля обработанного видеоматериала, что помогает сохранить цветовую согласованность после применения моделей искусственного интеллекта. Включает в себя гибкий ползунок (0–1) для точной настройки в соответствии с вашими потребностями.
- Добавлен автоматический «шаговый режим» для графических процессоров с объемом видеопамяти менее 6 ГБ, чтобы предотвратить скрытые сбои при инференции и обеспечить надежный экспорт.
- В разделе «Настройки» -> «Экспорт» добавлены параметры формата цветности YUV, включая 4:2:0, 4:2:2 и 4:4:4, что обеспечивает более точную выборку цветов для различных рабочих процессов.
- Установить программу, отказаться от первого запуска.
- Скопировать файл Aiarty Video Enhancer.exe из папки crack в папку установленной программы с земеной.
- Можно пользоваться.
